multiphase flow in porous media
Old   February 15, 2005, 14:22
Default multiphase flow in porous media
zhou
I am trying to model liquid-gas flow in solid porous media by applying multiphase model (Eulerian model) in Fluent. Either gas or liquid could be primary phase. I got three questions. (1). When i define the secondary phase, i find i have to specify the diameter. However, either gas or liquid is not existed as bubbles or droplets in porous media. It is like a mixture of them. By the way, if i use mixture model, it has the same problem that i have to specify diameter. This problem is not existed in VOF model. I defintely do not want to specify diameter like VOF model does. So How do i solve this problem in Eulerian model? (2). Is Volume fraction solved as a variable in Eulerian model? If it is, which equation is used to solve this variable? (3). If gas and liquid occupy simliar volume fraction in porous media, which one should be defined as primary phase?
Thanks.
Old   February 18, 2005, 12:19
Default Re: multiphase flow in porous media
Amir
Hi I was really interested in seeing if someone respond your question or not as I am kinda working on the same issue but apparently noone did. though mine is VOF in porous media as I am interested in tracking the front face. let me know please if you find out more about your problem
Amir
Old   August 9, 2012, 08:10
kaci fodil
reynolds039 is on a distinguished road
i am working on the same problem , i thik that if we are interresting on the front of the interface we must use VOF, in the eulerian model the particules are in movement , and because of that we should define the diameter of the grain
reynolds039 is offline   Reply With Quote
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
flow thru porous media, PLEASE HELP Goker FLUENT 4 September 8, 2012 05:02
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 05:50
rotating porous media in a general flow a_dores FLUENT 0 October 31, 2010 05:50
turbulence flow in porous media wei rong FLUENT 1 August 5, 2002 11:47
