import mesh error/warning
Old   February 15, 2005, 09:47
Default import mesh error/warning
Laxminarayana
While importing a mesh from patran all groups got imported as seperatre zones in Fluent but surprisingly I notice some warnings shown below and the two following zones got split into two additional zones. Can anybody help me to say why it is happening so. I want to avoid them happening
Thanks in adavance Laxminarayana
A snap shot of import work....
PATRAN file to RAMPANT file
Read 187642 nodes, 204246 elements, 14 groups.
33884 quad elements 170362 hex elements 187642 nodes.
280 quadrilateral velocity-inlet faces, zone 1.
4190 quadrilateral wall faces, zone 2.
4190 quadrilateral wall faces, zone 3.
320 quadrilateral velocity-inlet faces, zone 4.
80 quadrilateral velocity-inlet faces, zone 5.
200 quadrilateral outflow faces, zone 6.
480 quadrilateral outflow faces, zone 7.
240 quadrilateral outflow faces, zone 8.
200 quadrilateral outflow faces, zone 9.
1680 quadrilateral wall faces, zone 10.
1700 quadrilateral wall faces, zone 11.
268 quadrilateral wall faces, zone 13.
268 quadrilateral wall faces, zone 14. 493888 quadrilateral interior faces, zone 16.
20044 quadrilateral wall faces, zone 17. 170362 hexahedral cells, zone 15.
Building...
grid, Note: Separating wall zone 13 into zones 13 and 12.
s1_hole -> s1_hole (13) and s1_hole:012 (12) Note: Separating wall zone 14 into zones 14 and 18.
s2_hole -> s2_hole (14) and s2_hole:018 (18)
materials,
interface,
domains,
zones,
s2_hole:018
s1_hole:012
default-exterior
default-interior
default-fluid
s2_hole
s1_hole
l_holes
no_slip
outlet_2
outlet_3
outlet_4
outlet_1
inlet_3
inlet_2
periodic_2
periodic_1
inlet_1 Warning: Thread 18 has 50 contiguous regions. Warning: Thread 12 has 50 contiguous regions.
creating s2_hole:018-shadow
creating s1_hole:012-shadow
shell conduction zones, Done.
Old   February 15, 2005, 09:49
Default Re: import mesh error/warning
Laxminarayana
The problem is with....
a) Warning: Thread 18 has 50 contiguous regions. Warning: Thread 12 has 50 contiguous regions.
b) grid, Note: Separating wall zone 13 into zones 13 and 12.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Mesh and geometry import in cfx-pre Francesco CFX 7 May 30, 2012 09:04
Unable to import mesh on the CFX-Pre jarrai CFX 1 December 20, 2010 08:05
CFX mesh import from ICEM (Windows) Andrew CFX 7 July 6, 2006 12:39
