boundry condition problem
Old   February 14, 2005, 16:42
Default boundry condition problem
arashshahin
in complicated models like a swirl 3d model.after i meshed model some region must not be wall and that regions must be free for flow of fluid but i don't know which one of properties in gambit must be select before i think that i must choose interior for that faces but it was not correct. please help me about complicated models . thank you. arash shahin
Old   February 14, 2005, 17:46
Default Re: boundry condition problem
researcher
i dont understand clearly what your problem is, but i advise you to define that regions you want flow through as pressure outlets. it's the easiest thing to do. it's so crazy that i might work.
Old   February 15, 2005, 08:05
arash shahin
i mean about two beside face that we must create for meshing but these faces must not be the wall. infact these faces must be there only for meshing we have to create these faces.in fact we create two seperate volume with one common faces . and my problem is iin this common face. thank you. A.Shahin
Old   February 15, 2005, 10:43
A
you have do define them as two different volumes in Gambit -> Zones -> Continuum FLUENT take care of the internal face automatically when you import the mesh into that.
Old   February 16, 2005, 02:01
arash shahin
but when i import them to fluent fluent take these faces as the wall automatically.
Old   February 16, 2005, 10:55
A
it doesn't happen if you do the same thing I said, even if that happens you can change that wall to interior in FLUENT, boundary condition menu
how get boundry condition to air return ducts honest FLUENT 1 July 11, 2011 09:48
Transient Simulation: Boundary Condition Problem Shafiul CFX 7 January 11, 2011 17:40
query about boundry condition for energy equation jugal44j FLUENT 0 December 4, 2010 05:53
tabular boundry condition!!! mehrdadeng CFX 2 August 3, 2010 16:25
wall boundry condition fred FLUENT 0 August 19, 2004 13:10
