Accessing flow properties at certain points inUDFs |
February 14, 2005, 12:26 |
Hi I need to obtain the velocity at a given point inside a udf. How can this be done? Thanks
February 14, 2005, 15:32 |
Re: Accessing flow properties at certain points in
You may loop over the cells, find their centroid with C_CENTROID and localize with an if clause the point you need.
Regards, ap |
February 14, 2005, 21:42 |
But how can I know if a certain point is contained in a cell? The C_CENTROID macro gives the coordinates of the centroid of the cell, but the point I have may not be exactly this, but still contained inside the cell. Isn't there a macro to determine if a point is inside a cell?
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 09:42 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 08:33 |
