February 10, 2005, 23:48 |
gambit problem... help!!
I try to load a file in gambit to edit the model but this thing came out; 'Error:This database was not properly closed' Can anyone help me with this. Thanks in advance. Sham. |
February 11, 2005, 01:47 |
Re: gambit problem... help!!
What ever directory you saved the model in, there's a ####.lok file you have to delete where #### is the same as the filename of the model. Gambit deletes this file on a normal shut down... the idea is to prevent someone from opening the same model while you are working on it... if Gambit doesn't shut down properly, it doesn't delete the file and you'll have to do it manually.
Hope this helps, and goodluck, Jason |
February 11, 2005, 03:08 |
Thanks Jason,
I can't find the ###.lok file in my directory and I have deleted all the files with ###.lok just to avoid gambit crashes. Pls advise. Sham. |
Gambit geometry problem | cestrin | FLUENT | 3 | July 4, 2012 03:33 |
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam | Rachid BANNARI (Bannari) | OpenFOAM Meshing & Mesh Conversion | 25 | September 11, 2011 08:58 |
Gambit installation problem | Panos | FLUENT | 4 | March 5, 2009 23:44 |
Problem meshing with Gambit | Adrian | FLUENT | 8 | October 7, 2008 09:39 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 12:09 |
