February 10, 2005, 07:26 |
Change Fluent.cas and .dat possible?
I am calculating the flow around a 3D airfoil. I have defined the boundaries as Wall, Pff, Symmetry. I would like to save Fluent.cas and Fluent.dat files without values on both "Symmetry" boundaries. Is there a solution? I can not save as *.prof as I need to keep the same format as .cas and .dat. Many thanks Pat |
Using .dat file geometries in ANSYS 12 | anonymatt | ANSYS | 0 | March 1, 2010 11:45 |
import .dat Datei | Bucke Flo | Fidelity CFD | 2 | December 17, 2007 02:38 |
problem with reading the .dat file,error object:#f | Paulina | FLUENT | 6 | November 7, 2006 15:49 |
ACCESS VIOLATION error opening a .dat file | DavidSF | FLUENT | 12 | April 8, 2005 15:37 |
Change BC during the run? | jx | FLUENT | 7 | November 6, 2003 20:45 |
