mass transfer in fluent 6.0.12 or 6.1.22
Old   February 9, 2005, 10:09
Default mass transfer in fluent 6.0.12 or 6.1.22
masood yooceframandi
dear sir do u know could fluent handdle mass transfer from wet-solid to hot gas(for example: in fluidized bed dryer)without using of UDF? regards masood
Old   February 9, 2005, 18:05
Default Re: mass transfer in fluent 6.0.12 or 6.1.22
someone
there is not such a sir here but a bunch of people helping each other, you will get better results with UDF for a FBD, read the user manuals they're spread all around the web.
Old   February 10, 2005, 11:57
dear someone!(or sir!) i said without UDF!is it impossible without UDF? regards masood
Old   February 22, 2005, 10:14
Default rotating blades?
mourad
I modeling a flow through two blades revolving in a cylindrical geometry, the fluid is note rotating, the blades are used just as scraping of the walls in interior of cylinder, when I have a strong shearing, what do you suggested choose as solution of this problem, Reference frames, moving wall or sliding mesh?
Thank you.
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Multiphase Mass transfer UDF issue therandomestname FLUENT 0 April 21, 2011 15:51
free convective and diffusive mass transfer rajani FLUENT 0 July 27, 2005 09:28
