Runing Out of memory in Gambit
Old   February 8, 2005, 19:43
Default Runing Out of memory in Gambit
Akin
I have 2Gb memory machine for Gambit, but I keep getting an abort message for not enough memory, what can I do ? is there a switch somewhere to take advantage of my memory ?
Old   February 8, 2005, 19:59
Default Re: Runing Out of memory in Gambit
zxaar
does this message appear whern you try to save the database files
Old   February 8, 2005, 20:00
Akin
It appears when I am meshing
Old   February 8, 2005, 20:02
zxaar
usually when you try to save and if you try to save on c: this message appears, (this means it has to be saved in c:\folder) ,,but it seems this bug is not reated to your problem
Old   February 9, 2005, 13:41
Evan Rosenbaum
Are you running on Windows? Windows memory management problems often give this error. If so, there is nothing you can do about it.
Old   February 9, 2005, 18:28
Akin
Yes I am running windows
Old   February 10, 2005, 16:32
Evan Rosenbaum
You have limited options. Try doing things in smaller pieces. For example, don't mesh 20 volumes at once, but do a few at a time. Also, make sure you are using the latest Gambit release (2.2.30). It contains fixes for some things that can lead to such errors.
running out of memory in Gambit, Help!!! ahmet FLUENT 19 October 5, 2013 07:01
tips for runing Gambit without Exceed in Win Vista Fabio Saltara FLUENT 9 September 23, 2011 14:59
In GAMBIT meshing, Out of Memory! ? Conan FLUENT 7 November 10, 2008 05:02
3d Gambit meshing shows out of memory tamjid FLUENT 3 September 27, 2008 02:01
memory -gambit costel FLUENT 4 July 11, 2008 07:09
