Interpretation of UDF Problem
Old   February 6, 2005, 13:11
Default Interpretation of UDF Problem
John
Help!! I'm trying to interpret a source file written in C, and I get the following error message:
cpp -IC:\Fluent.Inc\fluent6.1.22/src -IC:\Fluent.Inc\fluent6.1.22/cortex/src -IC:\Fluent.Inc\fluent6.1.22/client/src -IC:\Fluent.Inc\fluent6.1.22/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" H:\Final tube model\unsteady.c
Error: H:\Final tube model\unsteady.c: line 1: parse error.
The source file i'm attempting to interpret has a .c extension, i don't know what to do, please help!
Old   February 6, 2005, 13:28
Default Re: Interpretation of UDF Problem
John
What's more to that, i'm alternatively trying to Compile (instead of interpreting) my "unsteady.c" file, and i'm get the following error message:
(system "move user_nt.udf libudf\ntx86\2ddp")0 (system "copy C:\Fluent.Inc\fluent6.1.22\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Done.
Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Please help, it's urgent!!
Old   February 7, 2005, 15:19
Allan Walsh
Make sure path is set so nmake will be found. You may need to read up on setting environment variables.
Then make sure you can compile one of the standard udf examples.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 01:43
I have problem of UDF with turbulent premx source. Z FLUENT 0 February 16, 2005 04:34
UDF problem chiseung FLUENT 4 January 10, 2002 10:58
