In-cylinder application
Old   February 6, 2005, 01:14
Default In-cylinder application
Yogesh
While doing In-cylinder application, I came across with some interesting findings. I am tring to simulate ideal compression process in 3D cylinder. After defining all In-cylinder parameters and zones details; I have solved the same case study with two different approach. In first one I gave the numebr of substeps in each timestep equal to 10 and in another one I gave 40. In both the cases, I found that the difference in maximum temperature is around 120 K ! which is amazing.
Above this in both the cases the maximum temperature achieved after compression is not matching with the value that calculted using analytical formula. My question is how to select the number of substeps which will give the approproate results for in-cylinder application? Has any body come across such situation? Can any one share his/her thoughts on this.
Regards, Yogesh
Old   February 6, 2005, 01:37
Default Re: In-cylinder application
Samir
number of time steps varies inversely to the time step size as far as i can recall doing an unsteady flow. The time step size is more significant a parameter than number of time steps. You would want to control the time step size and then calculate the number of time steps. There is a threshold value that you can calculate for a time step size using any of the CFD books available.
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 04:56
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
