Fluent vs. CFX
Old   January 26, 2005, 12:50
Default Fluent vs. CFX
_stephen_
I am about to simulate a big atrium with Fluent. however i was wondering if i should switch to cfx for the thermal and fire/smoke simulation since i saw some very good cfx sample cases for that matter.
could anyone post a comparison or some advantages of either one please?
Thanks in advance
have a nice day!
Stephan
Old   January 26, 2005, 17:09
Default Re: Fluent vs. CFX
zxaar
i am not sure about higher versions of cfx, but i used to work with cfx4.3 - cfx4.4 ..the only point i want to say is i found that cfx had very good documentation, at least an example on every case they do, and with fluent the tutorials are very less compared to what fluent can do.. so might not have come across any example fire/simulation (as i rem cfx 4.4 has an example of one such case in example manual)
Old   January 26, 2005, 18:56
schwille
You might consider looking at NIST's fire code FDS, which is specifically designed for applications like this. Also, it's free.
Old   January 27, 2005, 03:36
Jens
My few cents,
Be very carefull with FDS, it soemtime gives wrong solution due to it treatment of the combustion and radition with regards to the mesh size! Also the lack of wall function in the LES model sometimes gives problem with separation of the smoke layer!
We use CFX very often for ventilation and fire simulations. It works very good and is very stable.
/Jens
Old   January 27, 2005, 07:04
Default Thanks for your comments
_stephen_
I really appreciate your input..
Best regards
Stephen
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 03:54
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 14:14
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 15:22
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 16:02
