compiling UDF
Old   January 26, 2005, 12:10
Default compiling UDF
joyce
I am trying to compile a UDF. I put the .c file and udf.h file in the same directory as the .cas file. there is no other .h file created by myself. When I clikc "build", it did create the directory and copy a few files in that directory, but when click "load" it gave me an error message say "Error: open_udf_library: The system cannot find the file specified."
Is there anyone can tell me why it happened and how to solve the problem?
Thanks a lot.
joyce
Old   January 26, 2005, 12:28
Default Re: compiling UDF
Diet
are you sure there aren't any syntax errors in your code? you should check the log file first in order to localize and correct the syntax errors.
greetz
Old   January 26, 2005, 17:44
Default no syntax errors
joyce
Thank you for your reply. There is no syntax errors, then how could this happen?
Thank you.
Bing Ma
Old   January 26, 2005, 18:01
joyce
Thank you.
Bing Ma
Old   January 27, 2005, 05:43
Default Re: no syntax errors
Diet
You don't have to put the udf.h file explicitly in your directory. just the .c file is enough. The rest(udf.h) fluent will find or create on its own... I think this could be the error, but i'm not sure... you can try this by deleting the udf.h file....
Diet
Old   January 30, 2005, 11:02
Swarup
Hi Joyce,
you should put your .c file in src folder that contains all sorts of UDFs in Fluent. you should not forget .c extension to your filename. the moment you compile your UDF, a file "udfconfig.h" is automatically created and you can leave it untouched.
This may help you. Regards, Swarup.
About UDF compiling issues: 'nmake' Haoyin Shan Fluent UDF and Scheme Programming 15 November 4, 2019 19:05
Compiling UDF on a cluster Adya FLUENT 1 December 14, 2009 12:30
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 01:43
udf compiling problem akr FLUENT 3 August 22, 2007 08:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 10:13
