Meshing irregular XYZ data
Old   January 25, 2005, 05:28
Default Meshing irregular XYZ data
Duncan
Hi all,
I am a bit new to this but I am trying to mesh a river-floodplain system for input into FLUENT. The data I have is irregularly spaced XYZ data from which i would like to interpolate between the points and make a 3d surface. Can Gambit do this, I notice that Gambit has a line interpolation tool although I am yet to find a surface interpolation tool. Does anyone know of any method in which i could mesh such a system which has quite complex topography?
Also on a secondary note, I am running Gambit 2 with Hummingbird Exceed 8 over a network but have a problem with the menu bars in Gambit being squashed craeting difficulties reading some of the options, does anyone know the reason for this?
Many Thanks,
Duncan.
Old   January 25, 2005, 17:48
Default Re: Meshing irregular XYZ data
Tarnz
Hi Duncan I had a very similar problem trying to create a surface of a complex dune system. At the end I gave up and produced first a raster (in a GIS) and imported a regular grid of the surface (X,Y,Z coordinates). With this I could create a face using the "vertex rows" tools and that produced quite good results. But I am very interested if somebody comes up with a more direct solution. Good luck
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 08:51
export data at nodes Meenu FLUENT 1 December 30, 2011 02:24
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[ICEM] Meshing from porous media out of CT data shohin ANSYS Meshing & Geometry 5 July 29, 2010 14:03
meshing axisymmetric problems with irregular boundaries mirko OpenFOAM 6 July 20, 2010 10:17
