read/define PROFILE
Old   January 20, 2005, 20:42
Default read/define PROFILE
ben h
Trying to define a velocity inlet (boundary layer) profile for the simple case of flow over a flat plate. Fluent has stated "reading profile file...", but has yet to move past this point. The file format is correct, is there a specific file extension (*.ext) that must be used? or is there another rather simple issue stopping fluent from reading the file? or is it a matter of time?
Old   January 21, 2005, 11:08
Default Re: read/define PROFILE
Tang
It should be in the form "filename.prof" this is what I use.
Old   January 23, 2005, 20:53
Tarnz
No, it doesn't need a file extension and it shouldn't take that long if your inlet is not extremely big. How many different values (velocity, turbulence etc) did you write onto the profile file and how many surfaces did you choose?
Old   February 1, 2005, 14:19
ben h
Thanks for the help. The problem was in the *.prof file itself. Fluent didn't like the name given to the profile before the "point ##" and there also needed to be parenthesis () around the entire text of profile coordinates. The boundary layer profile file needed some manipulation before fluent would accept it. So instead of reading the file it just froze at the part it didn't like.
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 07:25
Boundary Profile E61 FLUENT 0 January 5, 2011 09:13
Having problem in using profile Jake FLUENT 2 May 8, 2008 16:49
problem with importing and exporting profile BC Gui CFX 2 July 26, 2007 09:50
Wind profile tom Phoenics 2 September 28, 2005 11:51
