The BC loss
Old   January 14, 2005, 01:05
Default The BC loss
Jackie
Hi all ,
I have a problem in modeling a rotating hot cylinder in a box (2D). I specify a cylinder surface as wall in Gambit but after export mesh. it's appear that this BC was not found in my BC lists in Fluent. How do I fix this problem ?, anybody help me please.
Jackie
Old   January 17, 2005, 08:03
Default Re: The BC loss
Jason
So you modeled it as a 2D problem, did I get that correct? If so, when you attached your BC it should have been attached to the edge (making sure the solver was set to Fluent 5/6), and when you exported your mesh you have to make sure to check the "Export 2D X-Y mesh" That might not be the exact wording, but it's a checkbox just under the filename box in the export mesh dialog window.
The only other thing I can think of is that there were two edges right on top of one another, and one of them wasn't connected to the mesh, and that's the one that you assigned the BC to.
If this doesn't help, then when you export the mesh, read the status window to see if there are any warnings or errors.
Hope this help, and goodluck Jason
loss calculation in simulation of turbomachines playmaster Main CFD Forum 0 August 21, 2010 06:59
SimpleFoam TotalPressure loss prapanj OpenFOAM Running, Solving & CFD 1 July 30, 2009 12:09
Mass loss! So what? jinwon park Main CFD Forum 13 May 22, 2008 10:29
How to deifmne head loss co effcint ? Angelina FLUENT 1 February 8, 2006 10:41
How to deifmne head loss co effcint in cfx? Angelina CFX 4 February 7, 2006 14:14
