question about writing an udf
Old   January 13, 2005, 04:27
Default question about writing an udf
Denitiu Marian
I'm trying to write an udf, to simulate a periodic flow through a geometry composed of a center cilinder, and three pipes which all comunicate with the central cilinder. They are placed at 120 degrees apart from each other. At a certain time, through one of the pipes, I have fluid coming inside the geometry, and through the other two, the fluid is coming out. I'm not really interested about the time variation, but I want the principle of the thing explained to me.
Here is what I wrote. It is based ont the oscilating pressure udf, found on the Fluent documentation disk. /
#include "udf.h"
DEFINE_PROFILE(unsteady_pressure, thread, position) {
float t, pressure; face_t f; float x,M;
begin_f_loop(f, thread) {
t = RP_Get_Real("flow-time");
x=(t/1.5);
M=t-1.5*x;
if ((M>0) && (M<0.5)) {
pressure = (0.12*sin(1748.8*t)+0.737)*101325.0;
else M=0;
if ((M>0.5) && (M<1) {
else M=0;
if ((M>1) && (M<1.5)) {
else M=0; F_PROFILE(f, thread, position) = pressure; } end_f_loop(f, thread)
When I try to compile it, I receive: Error: c:\fluent.inc\pexit1.c: line 36: parse error. Error: c:\fluent.inc\pexit1.c: line 39: parse error. Error: c:\fluent.inc\pexit1.c: line 49: parse error.
Any ideas?
Old   January 13, 2005, 06:19
Default Re: question about writing an udf
Andrew Garrard
You will never get to the second two if ... else statements. When M is assigned a value in then enters the first if else. if it is between 0 and 0.5 it changes pressure. if not M becomes 0. This means that it won't enterd the remaining two if else statements.
Old   January 14, 2005, 07:28
wanghong
try to put your udf on your computer table,perhaps "parse error" will not appear again.
Writing UDF for DPM Cantstandit Fluent UDF and Scheme Programming 5 September 20, 2010 21:30
New to writing UDF Sandilya FLUENT 0 May 31, 2007 13:03
Question to UDF Claud FLUENT 1 April 10, 2007 18:02
A question about UDF owet.L FLUENT 4 December 20, 2005 04:19
A question about the dynamic mesh UDF Tango FLUENT 1 November 27, 2003 03:56
