GAMBIT start-up
Old   January 13, 2005, 03:54
Default GAMBIT start-up
Pre
I'm trying to start-up GAMBIT and the following error message appears in the command window.
"GAMBIT is not recognised as a internal or external command, operable program or batch file"
Old   January 13, 2005, 04:12
Default Re: GAMBIT start-up
Sundar
Try using the command gambit !
Old   January 13, 2005, 04:26
HVN
Check your environment variables.
Old   January 13, 2005, 04:36
Pre
I did use the command GAMBIT in the command window and then it gives the error.
Old   January 13, 2005, 04:39
Sundar
I told you to use the commang gambit and not GAMBIT. If you anything to say can you write to me at ksvv@hotmail.com or catch me at msn !.
Good luck Sundar
Old   January 13, 2005, 08:22
Pre
Thanks-solved the problem. It was the environment variables taht needed to be modified. Thanks HVN
[GAMBIT] Canīt start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 02:05
gambit crashed mbgnfrx2 FLUENT 1 August 13, 2009 04:31
gambit start Zhiqiang An FLUENT 2 March 31, 2003 12:34
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 23:26
Lets start the public domain CFD-Project! Heinz Wilkening Main CFD Forum 3 March 11, 1999 23:55
