January 11, 2005, 19:29 |
Gambit input files
Hi guys,
I know Gambit can read in x-y points, but is there a way to make an input file that defines not only the vertex points, but also edges, faces and volumes? I would also like to know if you can define grid spacing and number of nodes on each edge. In case you are wondering, there is a huge parametric study in my future ;-( |
January 14, 2005, 09:12 |
Re: Gambit input files
Absolutely you can. Look at the Command Reference Guide. You can write text file programs (journal files) that create vertices, edges, faces, volumes, and that mesh them. Your program can call other journal files, write mesh files, use do loops, define parameters and use them in any of the commands - it's pretty easy and versatile. I recently did a 5^4 full factorial computer "experiment" or parametric study this way with do loops nested 5 levels deep.
[Commercial meshers] Error: Could not find feature gambit in license file(s). | nirmalrishi | OpenFOAM Meshing & Mesh Conversion | 1 | December 4, 2009 11:16 |
dxf files and gambit or fluent | Lio | FLUENT | 6 | June 23, 2004 10:41 |
how to mesh iges files with gambit 2.0 ? | Lionel | FLUENT | 2 | June 23, 2004 03:06 |
Joining Files in Gambit | jens | FLUENT | 4 | February 23, 2004 02:50 |
Journal files of Gambit & Fluent | Arif Saputra | FLUENT | 6 | September 10, 2001 04:29 |
