Only if inviscid model, errors re temp limit, FPU
Old   January 10, 2005, 20:00
Default Only if inviscid model, errors re temp limit, FPU
Chris Bailey
I'm modeling a simple geometry with air flowing through it and trying different "viscous..." models with energy (heat transfer) on. All work nicely, except the "inviscid" model generates errors below. I'm setting temps on three boundaries in the several hundreds, and limiting temp to 200 to 700 range. Is there some special interaction between inviscid models and temperature? Or some other special sensitivity of inviscid models to floating point errors?
> iter continuity x-velocity y-velocity energy time/iter
temperature limited to 2.000000e+02 in 1808 cells on zone 2 1 Error: Floating point error: invalid number
Error Object: ()
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
what is the relationship between inviscid model an charles FLUENT 2 September 8, 2004 10:18
inviscid model for ship Liang FLUENT 1 January 15, 2002 12:00
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
