On the far field boundary conditions.
Old   January 10, 2005, 03:13
Default On the far field boundary conditions.
mini
During the simulation, I need to use the far field boundary conditions, i.e. free boundary conditions for the incompressible ideal gas, but in the Fluent, the pressure far field boundary conditions is only for the compressible ideal gas, so, I don¡¯t know what I should do. Help, please. Thanks.
Old   January 10, 2005, 05:01
Default Re: On the far field boundary conditions.
Luca
What kind of simulation are you doing?an aircraft or car analysis?
Old   January 10, 2005, 06:13
mini
Far field of the jet, what should I do? thanks
Old   January 10, 2005, 06:16
Luca
Use the pressure-outlet BC.
Old   January 10, 2005, 08:23
mini
How can I set the pressure value?
Old   January 11, 2005, 13:39
someone
you're gonna get some reverse flow. so place the pressure outlets as far as you can.
Old   January 11, 2005, 17:11
RIaan
Use Pressure Far-field and set your gas to Ideal gas regardless.
If you suspect your flow mach number is low enough to avoid compressibility effects (Ma <0.3), you should still get the same solution even though you use the ideal gas/Pressure far field.
Old   January 11, 2005, 21:53
mini
I see. Thank you for you help.
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 13:16
how to give boundary conditions:-calculated type of primitive boundary field suniljain OpenFOAM Running, Solving & CFD 1 March 20, 2010 01:19
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
