should i use fea or cfd for thermal analysis?
Old   January 4, 2005, 10:26
Default should i use fea or cfd for thermal analysis?
mr. bill
Hello all, i need to complete analysis of an electronic box which includes an enclosure, pcb and processors, cooling fan, heat transfer via free convection, forced convection, radiation. need to determine component temperatures inside the enclosure.
My question is can i capture the results with an fea package such as nastran (fea) or do i need a cfd package like fluent?
thanks a billion, mr. bill
Old   January 4, 2005, 20:15
Default Re: should i use fea or cfd for thermal analysis?
Aravind
You should use a CFD package instead of FEA package. Since CFD packages can capture the effects of fluid flow better than FEA packages. The case would be different if you are considering conduction only. In that case an FEA package would do a good job.
Aravind
Old   January 4, 2005, 20:25
mr. bill
Aravind thanks for your response. i have nastran and it allows me to enter convection surfaces. is this still not advisable for a convection analysis.
also what about radiation? will fea do okay with radiation if i can input the view factors?
peace
mr. bill
Old   January 5, 2005, 09:39
Jonas Larsson
I'm not at all an expert in electronics cooling, but I'll give my $0.02 anyway. You probably don't don't want a full-featured CFD package like fluent. I'm not sure if you even need a CFD package at all - someone who knows the tools and tricks of electronics colling will have to advice you on that . In any case, if you do find that you need to do CFD computations, there are a bunch of specialized tools that will most likely both produce better results and be easier to use than a general purpouse CFD code.
The leading tool I think is Flotherm from Flomerics www.flomerics.com . Flotherm is closely followed by IcePak www.icepak.com from Fluent. There are also a number of other packages like for example the tools from Maya www.mayahtt.com
You might also want to check out www.coolingzone.com Although that site is a bit affiliated with Flomerics it might give you some more insight.
Good luck.
Old   February 6, 2014, 06:22
Default Need a help plaese-ICEPAK 14.5 TOOL
Pinkey is on a distinguished road
Hi All,
I am new to CFD Domain & ICEPAK tool as well.
Can anyone explain me as to how/on what basis the reynolds & peclet numbers are calculated(In solution settings option itself by clicking on the refresh button).
I am working on Finned heat sink model (tutorials).
Please help me out.
Thanks
Pinkey
Pinkey is offline   Reply With Quote
Old   November 18, 2014, 00:54
Smile
sivamsakthivel's Avatar
sakthivel
sivamsakthivel is on a distinguished road
Send a message via Skype™ to sivamsakthivel
Originally Posted by Aravind
;116934
Aravind
Hi Aravindh,
I too face same problem, currently i am using Ansys steady state thermal analysis for free convection. Is there any possibilities to do forced convection in ansys ?? if yes menas how ??
Thanks in Advance.
sivamsakthivel is offline   Reply With Quote
Old   May 18, 2015, 07:54
Default Hi
Pramodh.J
Jupudi.pramodh is on a distinguished road
Send a message via Skype™ to Jupudi.pramodh
Well,
Before anything else, CFD is a branch of physics (fluid mechanics) and FEA is a technique. A Problem in CFD can be solved using FEA/FEM or FVM or FDM as well. even though FDM is kind of absolete due to it's limitations on mesh, FEM & FVM are widely followed across the globe (atleast as far as folks I've come across). As described by my professor, FE codes are quite robust and provide a stable solution as compared to FV solvers. Still the reason for using FV solvers like Fluent, Star CCM etc over FE solvers like Comsol & Acusolve is , FV solvers are flexible with different mesh types and can easily handle grid counts upto few millions with ease which is a distant dream for a FE solver (cos it takes huge computational power for same grid).
Coming to software packages, the main discussion, tools like ansys classic, nastran etc., though have CFD capabilities, some times fail in case of complex physics. If you're more concerned about flowrates, heat fluxes and pressure gradiants across the domain, it's advised to go for dedicated CFD tools like Fluent, CFX, Acusolve, Star CCM , openFOAM etc.
When it comes to electronics cooling, as Jonas Larsson suggested, you can go with Icepak / FloTHERM, which are dedicated tools for electronics thermal management and are easy to use.
Jupudi.pramodh is offline   Reply With Quote
Old   March 3, 2016, 15:31
Onurhan Gökalp
Onurhan Gökalp is on a distinguished road
Hi everyone,
I am researching same subject and i can't find a related article in sciencedirect. I am trying to get information for cfd analysis of cooling of electronic board with forced convection of air. i have tried "electronic board cooling, electronic cooling, electronic chip cooling with forced convection" ect. as keywords but the result is the same. I can't find what i want
What should my keywords be ?
Best regards.
Onurhan Gökalp is offline   Reply With Quote
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 11:51
Mapping CFD results into FEA chittoorreddy STAR-CCM+ 5 August 17, 2009 05:18
CFD Analysis of pump remith CFX 7 October 6, 2008 08:57
Status of FV versus FEA research in CFD diaw Main CFD Forum 8 February 11, 2005 01:52
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
