December 27, 2004, 22:09 |
geometry in gambit
hai ,
I'm having a geometry of 1.4 m dia cylinder. For which i have already made case files and declared the boundary conditions and this species transport model is working as per my requirement. Now my intention is to change its dia to 1.1 m. Is it possible to change its dia in fluent itself so that meshing time and boundary conditions declaration and defining time can be saved. Is there any other means to do the job soon or again i have to create the geometry in gambit and again meshing , defining has to be done. awaiting for ur quick and positive response |
December 28, 2004, 03:08 |
Re: geometry in gambit
Unless there are any other changes in your geometry, you could use scale option in Fluent without returning back to Gambit. Retain the units but change the scale factor, then you should update your BCs as well. Regards, Emre |
December 28, 2004, 03:30 |
hai emre
hai emre,
thanks for your reply. I'm having 1.4 m dia cylinder of height 5m at bottom and it has frustrum of cone at its top. and one cylinder is placed on it. and hemisphere on this cylider. I need not change any other dimensions expect the bottom one to 1.1 m for 2m from the bottom. the remining 3 m is going to be of 1.4 m.I need not change any boundary conditions and all other parameters are going to remain same. could you suggest how to do this. |
December 28, 2004, 04:17 |
Re: hai emre
I suppose you need to spend some time with Gambit to do that, there is not a direct easy way to do that in Fluent as far as I can see. But from TUI write file, write b-c and save the boundary conditions to a file. Then you can read it to the new model by typing file, read b-c. If you could foresee this change in your model at the beginning and create a different zone at the bottom of the first cylinder, then you could deactivate that zone and need not to return back to Gambit. Regards, Emre |
December 28, 2004, 04:29 |
Re: hai emre
Thanyou emre,
I will try this and reply u soon regarding the effect. keep in touch. --soundar |
[GAMBIT] how to mesh a 3d spiral geometry in gambit | seyedashraf | ANSYS Meshing & Geometry | 9 | July 4, 2013 05:42 |
create turbine geometry with gambit | badlaine | ANSYS Meshing & Geometry | 2 | March 26, 2012 23:54 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
What can I employ to create geometry besides Gambit? | summer | ANSYS Meshing & Geometry | 2 | February 11, 2011 14:50 |
problem about Importing geometry in Gambit | Hua Gu | FLUENT | 3 | April 2, 2002 14:24 |
