December 20, 2004, 05:12 |
2-D Compressible Axisymmetric modelling
hi.
i am modelling flow over Cone in 2-D AXISYMMETRIC. Flow is compressible and mach no is 1.3 . goemetery starts at (0,0) and is above x-axis (the axis of revolution) the problem is that the solution diverges. i have tried all the turbulence models. the same case when solved in simple 2-D case the solution converges well with all the turbulence models. The Cd (coeff of drag) with the Simple 2-D case is slightly on the higher side hence i am going for the axisymmetris case any help would be appreciated |
Modelling Unsteady Compressible Flow | Vince! | FLUENT | 0 | March 10, 2004 11:23 |
Modelling Unsteady Compressible Flow | Vince | Main CFD Forum | 0 | March 10, 2004 11:01 |
Compressible Flow Modelling? | yeo | FLUENT | 4 | March 7, 2003 07:08 |
Axisymmetric Inviscid Compressible Euler code. | Amith | Main CFD Forum | 2 | June 10, 2002 23:32 |
turbulence modelling in compressible transsonic flows | Bart Prast | Siemens | 0 | February 3, 2000 09:44 |
