temperature error
Old   December 12, 2004, 15:14
Default temperature error
H
temperature limited to 5.000000e+03 in 26 cells on zone 3 in domain 1 temperature limited to 5.000000e+03 in 80 cells on zone 4 in domain 1
Inspite of the above, I am getting convergence in my model. Are the results given by my model correct?
Old   December 13, 2004, 18:31
Default Re: temperature error
ap
FLUENT, as many solvers, has limiting functions to try to keep stable the solution. The result can be correct if the temperature in the real case doesn't reach the value imposed by the limiter, while it isn't correct if the temperature could reach that value.
Usually it should be better to avoid the limitation by properly setting the solver according to your peculiar case.
Hi, ap :-D
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
