Target mass flow rate
Old   December 10, 2004, 05:18
Default Target mass flow rate
Saturn
I used FLUENT to simulate the axial fan static pressure in the pipe.
Now I have known the mass flow rate from experiment. I set the pressure oulet condtion in the outlet.and set the target mass flow rate.
Then I opened the monitor of mass flow rate in the oulet.
But the mass flow rate was not my set value in the outlet during the iteration.
I set target mass flow rate is 0 CFM,but simulation was 225 CFM.
My axial fan rotation speed was 5570 RPM.
Could someone tell me why the simulation mass flow rate was different from target mass flow rate???
Thanks a lot!!
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 15:10
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 21:33
Regarding Target Mass Flow Rate Ravinder Yerram FLUENT 3 October 22, 2011 08:05
mass flow rate error Masood FLUENT 0 May 22, 2005 01:32
Target Mass Flow Rate Tang FLUENT 2 May 13, 2005 12:56
