compiled UDFs
Old   December 8, 2004, 11:29
Default compiled UDFs
Jianli
HI, I am new for Fluent, and I am using UDF for a reaction kinetics. When I tried to use Define---User Defined---Functions--complied after I "ADD" source file, when I click "Build" I got following message:
================== The system cannot find the file specified.
1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2d")0 (system "copy S:\CAEN\FLUENT6122\fluent6.1.22\src\makefile_nt.ud f libudf\ntx86\2d\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Done.
When I click Load: message was as follows:
========= Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: () =======================
What were wrong? Could anyone help me?
Thanks a lot!
Jianli
Old   December 8, 2004, 12:41
Default Re: compiled UDFs
Luca
you have q problem compiling your UDF. Make sure you have Microsoft Visual C++ installed otherwise under Windows you cannot use the compiled UDF. Luca
Old   December 8, 2004, 13:04
Jianli
Hi, Luca,
Thanks a lot for your reply. I am using WindowsXP with Microsoft Visual Studio .NET 2003. How could I set path to run compiling correctly in Fluent?
I could not run Fluent when work in Microsoft Visual Studio .NET Command Prompt windows. 'Fluent' is not recognized as an interal or external command......
Have a nice day!
Jianli
Old   December 8, 2004, 13:13
Luca
Try to search in the forum for other people having your same problem. I had your same problem with MS Visual Studio. I solved it by typing in a MS-DOS windows (in the directory c:\programs\visualstudio\vc98\bin VCVARS32 and then launching Fluent. It should works for you too. Otherwise you can reinstall MS Visual Studio and select the environment variables during the installation. Hope it helps. Luca
Old   December 10, 2004, 12:20
Jianli
thank you very much. I got it work.
Have a nice day!
Old   December 14, 2004, 04:20
raintung
What is the difference between the computational results with FLUENT 2D and FLUENT 3D for the same problems.Thanks.
Interepreted Vs. Compiled UDFs Antonis Fluent UDF and Scheme Programming 10 March 22, 2018 12:15
Compiled UDFs - questions Antonis FLUENT 6 December 26, 2012 07:12
Using compiled UDF:s in different Fluent versions S H FLUENT 1 September 12, 2007 04:40
accessing udf_library for compiled udf's Asghari FLUENT 0 August 9, 2006 05:41
Compiled UDFs Devin FLUENT 4 October 28, 2003 21:47
