Hello all,
I am trying to fix upthe density values in a three dimensional cylindrical enclosure for which I give the density distribution at each cells. I am using species transport model. Interpreting does not display any result but when iterated Fluent displays error saying "chip-exec: den_adjust: wrong return type: float udf function expected" Could you please help to solve this problem. The udf i used is #include "udf.h" DEFINE_ADJUST(den_adjust,d) { Domain *d; Thread *t; cell_t c; FILE *fp1; real arr1=0.; fp1=fopen("densitynew.dat","r"); begin_c_loop(c,t) { fscanf(fp1,"%g",&arr1); C_R(c,t)=arr1; } end_c_loop(c,t) printf("The density of cells are patched successfully"); fclose(fp1); } |
Well I am unfamiliar with reading in data from a file, but from your UDF I can see that you are trying to conduct a cell loop over a thread that has not been defined. I don't know if that is causing your error, but if it isn't, it would cause a different one.
When I am creating UDF's I usually make them very simple, see if they work and then increase the complexity. That way de bugging becomes very easy. Try getting C_R(c,t) to be a constant value first, and see if that works before trying to read from a file. |
Thanks Andrew for your attempt. But i have tried with declaring the cell values with a constant density also. I face with the same error. I hope that this error is not due to the variable values but in some other thing. Whats wrong in "return type" that could be seen in the error message?
chip-exec: den_adjust: wrong return type: float udf function expected |
If you amend your UDF like following, The problem may be solved.
#include "udf.h" DEFINE_ADJUST(den_adjust,d) { Thread *t; cell_t c; FILE *fp1; real arr1=0.; fp1=fopen("densitynew.dat","r"); thread_loop_c(t, d) { begin_c_loop(c,t) { fscanf(fp1,"%g",&arr1); C_R(c,t)=arr1; } end_c_loop(c,t) } printf("The density of cells are patched successfully"); fclose(fp1); } |
It the first part of my message I mention this:
Well I am unfamiliar with reading in data from a file, but from your UDF I can see that you are trying to conduct a cell loop over a thread that has not been defined. When you invoke the cell loop, you are applying a condition to every cell on a particular "cell thread". You delcare a thread pointer, in your case *t, but you do not tell the UDF what thread it is. You will need to put in a line something like this Thread *t = Lookup_Thread(ID, dom) Where ID is the boundary ID, avaliable in the boundary condition panel and domain is your domain pointer, as passed in the argument of the DEFINE_ADJUST. There is more info at 6.5.7 in the UDF manual. |
Try using a
DEFINE_PROPERTY(lem_density,c,t) { real rho; rho = ... return rho; } and hook this to density in the Materials panel |
UDF species equations | louiza | FLUENT | 4 | March 10, 2010 01:20 |
PB: Saving mass fraction of species on two points with an udf | biget.a | FLUENT | 2 | July 23, 2009 03:06 |
Model foaming process: change the volume / density | pmp77 | CFX | 0 | November 18, 2008 09:53 |
Species Transport with Multiphase flow in FBR | venkat | FLUENT | 1 | July 23, 2008 23:53 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
