Parallel UDF
Old   December 3, 2004, 23:17
Default Parallel UDF
ccc
hi everyone,
does anyone has the experience on using parallel UDF? please help me.
I try to use parallel version fluent(6.1.22) on two PCs(windows xp os). if no udf is used, everything is ok. when I try to load my udf, the fluent will cease after loading the host one, just like this,
Opening library "libudf"...
Library "libudf\ntx86\3d_host\libudf.dll" opened
Initializing
ending
Rocket The same code has been successfully used on a PC with two CPUs.
Can anyone tell me what's wrong?
Thanks in advance.
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 10:48
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 14:53
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 12:19
UDF in parallel version. yobee FLUENT 0 August 17, 2004 05:12
