November 26, 2004, 06:37 |
Energy balance problem
I have simulated a non-premixed combustion (wood): Through an injection I put 400g fuel in my combustion chamber and through a mass flow inlet 9 kg air. The system converges. The fuel is an empirically defined stream with a lower caloric value about 17 MJ/kg (C: 32% H: 47% O: 21% N: 0%). When I examine the fluxes, I realise that the combustion is much too cold: Only 1,35 MJ net heat-transfer reports fluent. The net mass-flow is about 369g which is a suitable value because some partikels are not completly evaporating. I think I should have 0.369 kg X 17 MJ/kg = 6,2 MJ; whats the problem ? |
November 26, 2004, 10:12 |
Re: Energy balance problem
Remeber that Fluent energy flux report's are the total enthalpy (thermal+chemical), while your calculation is only thermal.
Energy Balance in Thermoacoustic problems | behrang2009 | Main CFD Forum | 2 | July 28, 2010 12:33 |
Energy & Mass balance in RES file | Lindel | Phoenics | 2 | October 23, 2008 20:18 |
Energy Balance | Harshad | CFX | 0 | March 5, 2008 07:36 |
HELP needed: Energy balance in gaseous combustion | James Willie | FLUENT | 11 | August 10, 2005 05:58 |
Energy balance | Julie Polyakh | Siemens | 9 | July 7, 2004 05:00 |
