Compressible flow in the nozzle
Old   November 25, 2004, 00:49
Default Compressible flow in the nozzle
Saturn
I have a question about compressible flow in tne nozzle.
If I have known the function that cross section area A via the distance X along centerline,A = 0.1 + x^2, inlet stagnation pressure(Pi) and outlet pressure(Po) in a nozzle, how should I got the Mach number via distance X relation use qusai-1D equation???
Thanks a lot!!
Old   November 26, 2004, 06:57
Default Re: Compressible flow in the nozzle
nabeel mohsin
hi, i think you want to know about solution method or any thing plz tell me can i help you nabeel
Old   November 29, 2004, 05:22
N Menon
mach number area relation.
if the flow is purely isentropic (can be assumed) centreline Mach number can be obtained using the following relation
A/A_star = (1/M^2)*(2/(gamma-1)*(1 + (gamma - 1)/2 * M^2))^((gamma + 1)/(gamma - 1))
A = area at any point in the nozle\ A_star = minimum area of nozzle (throat area) gamma = 1.4 (for air) M = Mach number
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 13:25
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 03:07
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 20:48
3-D Compressible Flow Boundary Conditions Tyler FLUENT 4 February 5, 2009 20:58
Axisymmetirc Compressible Flow in a C/c and Nozzle Nauman FLUENT 0 December 21, 2004 08:40
