Exporting Boundary Conditions
Old   November 23, 2004, 15:35
Default Exporting Boundary Conditions
Andrew
I am currently running an aircraft model in Fluent with the engine integrated into the aircraft. I have had success with cold flow simulations, but unfortunately the computing power at my University is not strong enough to run such a case with combustion taking place.
Parallel processing is obviously the way to go, but we are also limited by the number of computers, so to run on two seperate computers, would mean I have to dislodge someone from their computer for the day or couple of days it takes to run.
I have an idea how I could do it a different way, which would take more time, but would fit in with the resources we have. Although I have no idea if Fluent can do this.
If I have an interior boundary condition setup on the inlet of the engine, would it be possible to read the interior boundary condition from the cold flow simulation of the complete aircraft and import it into a totally seperate new model as the inlet which would just simulate the engine?
Then do the opposite, by exporting the exit conditions of the engine into the cold flow model.
Any help will be greatly appreciated,
Thank you
Andrew Clark
Old   November 23, 2004, 17:20
Default Re: Exporting Boundary Conditions
Jason
I believe you can do this using profiles.
Chapter 3.9 of the user manual tells you how to write a profile from your "inlet" boundary condition on your aircraft model, then you can apply your profile to the "inlet" boundary conditions on your engine model. Chapter 6.26 tells you how to apply a profile to a boundary condition.
I've used this to create boundary layers and other velocity profiles, but I have never written a profile before, I've always had to write my own, so you'll have to let me know how it goes. My only concern is your exit conditions for the engine may change when you include combustion.
Anyway, like I said, you'll have to let me know how it goes, and if you need any more help, just post it here, or send me an e-mail.
Thanks, Jason
Old   November 23, 2004, 18:17
Andrew
Thank you very much for the help... as I have never done this before, I wasn't sure whether that was the command or not...
I will let you know how it goes...
Andrew
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 08:21
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
