Problem using ideal gas
Old   November 23, 2004, 15:17
Default Problem using ideal gas
mark
I am running a heat transfer problem and trying to implement the ideal gas equation to model my density. I am using rke two layer model for turbulence. When I use constant density or even incompressible ideal gas, the solution converges nicely in less than 2000 iterations. However, as soon as the ideal gas is chosen, the solution limits the pressure (regardless of what range of pressure values I use). Has anyone else experienced a similar problem?
Old   November 24, 2004, 04:32
Default Re: Problem using ideal gas
ROOZBEH
Hi; For compressible calculations, it is better to choose "Coupled" solver not "Segregated". Then you should start calculations with a very low courant number in solution panel (for example .001). After several iterations, you can increase courant number to 0.5 or ..., slowly(.001 then .005 then .01 and ...). Hope this help you. ROOZBEH
Old   November 24, 2004, 07:07
nabeel mohsin
hi have you selected energy equation to solve nabeel
Old   November 29, 2004, 17:40
mark
yes, I am using the energy equation
Density and compressiblity Mohsin FLUENT 7 June 7, 2015 23:23
Periodic Interface (Ideal Gas) Massflow Control Zigainer CFX 0 July 25, 2011 12:43
gas through porous media problem jiguozhao CFX 2 February 25, 2011 03:14
Setting initial amount of ideal gas David FLUENT 0 November 2, 2007 09:35
difference between ideal gas and incompressible? Ric Main CFD Forum 1 March 24, 2007 13:07
