UDF example
Old   November 23, 2004, 06:43
Default UDF example
anni
Hello friends,
I believe that UDF manual is very badly written. I have succeded writting a UDF that is finally working and i want to share it with you, so people can have more examples , trying to write one...
A disk rotating and the angular velocity increments with time, till time reaches the 1.5 s. After 1.5 sec the rotation of the disk is 600rpm . In FLUENT I can only give UDF x,y velocity components and not rotational velocity. In my case the center of the axes is at the center of the disk.
__________________________________________________ ___
/*UDF for specifying a transient speed for disk */ #include "udf.h"
DEFINE_PROFILE(x_velocity, thread, position)
real x[ND_ND], y, u_vel, ron, rol, nn, nl, r;
real t = CURRENT_TIME;
face_t f;
r = 0.08; /* disk radious [m] */
nn = 400; /* [rpm] */
nl = 600; /* the final [rpm] */
ron = 2 * 3.14 * nn/60; /* rotational velocity [rad/s] */
rol = 2 * 3.24 * nl/60;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
if (t<=1.5)
u_vel = ron * r * t ; /* u=(w*r)*t */
F_PROFILE(f, thread, position) = u_vel * (-y)/r ; /* x-component of velocity */
else
u_vel = rol * r ; /* u=w*r */
F_PROFILE(f, thread, position) = u_vel * (-y)/r ; /* after 1.5 sec */
end_f_loop(f, thread)
__________________________________________________ ____
DEFINE_PROFILE(y_velocity, thread, position)
real x[ND_ND], xc, u_vel, ron, rol, nn, nl, r;
face_t f;
nl = 600; /* rotation after the 1.5s [rpm] */
xc = x[0];
if (t<=1.5)
F_PROFILE(f, thread, position) = u_vel * xc/r ; /* y component of velocity */
else
F_PROFILE(f, thread, position) = u_vel * xc/r ; /* time > 1.5 sec */
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
