November 21, 2004, 04:05 |
vector plots-reg.
Friends,
I am simulating a 3d pipe flow. The pipe is inclined at angle say 30 degrees about the x axis, which is the rotation axis of the pipe. When I view the normal components at a cross-section in the cartesian and cylindrical coordiante systems, it looks different. Can I expect the flow patters formed by these normal components to be similar in both corodinate systems?Is this correct. I personally feel taht the patterns must remain the same in whichever co-ordinate system we view the plots! Anyway i require an answer from your side. Kindly help me out. Thanks |
Reg - Vertical Axis wind mill analysis | ADAIKALARAJA | Siemens | 4 | June 3, 2009 03:23 |
Reg. BICGSTAB | sandy | Main CFD Forum | 37 | June 24, 2008 11:25 |
Reg - Solve problem in Gasifier | S.SIVAKUMAR | FLUENT | 1 | October 12, 2005 03:55 |
reg .es-ice | anand | Siemens | 0 | May 12, 2005 09:27 |
reg. ES - ICE | anand | Main CFD Forum | 0 | May 12, 2005 08:42 |
