convergence problem
Old   November 20, 2004, 21:25
Default convergence problem
sarah_ron
Dear all,
I have a question about convergence criteria by using surface motior. If the residual is oscillatiing but lower than 1e-3 and surface monitor is also oscillating around a constant, is the solution converged?
Any reply is welcome.
regards, sarah
Old   November 21, 2004, 12:54
Default Re: convergence problem
akbar
Dear my friend
I have a suggestion for convergence criteria. in addition to residuals you can plot the variation of a parameter as velocity magnitude at a point in your flow domain as the fluent runs. if the magnitude of this parameter reaches to a constant value it means that the solution is converged. hope it will help you.
Best wishes A.safarzadeh
Old   November 21, 2004, 13:52
Anton
What are you trying to simulate? It could mean that your problem is unsteady. You could change to the unsteady solver and monitor the surface variable with time to see if it exhibits an oscillatory pattern.
Old   November 23, 2004, 00:48
Default Thanks a lot
sarah_ron
Hi,dear
Thank you all for kind reply! I will try according to your advise.
sarah
Old   November 24, 2004, 05:39
Default Re: Thanks a lot
nabeel mohsin
hi, in monitors if residual is reducing with simulation then it is going to converge
Old   November 26, 2004, 10:49
Default To nabeel Re: Thanks a lot
sarah_ron
Thanks a lot!
could you give me more hints?
thanks
sarah
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
