November 14, 2004, 12:52 |
Swirling in Fluent
Dear all, Has anybody tried to use the rotating disk described in White's textbook to test Fluent's ability to model swirling flow? My results are not consistant with the theoretical solutions. Any thoughts? thanks. My model: (1) axisymmetric swirl, (2) radius is 1 m, height 10 m (3) segerated laminar steady (4) ratational moving wall for the disk (5) top surface and side surface are "pressure_outlet"
November 14, 2004, 19:10 |
Re: Swirling in Fluent
if using much finer mesh, the results are close to the theoretical results. However, the velocities of corners and axial velocity at the outer surface still messed up. I guess I have to use much finer mesh to correct them.
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 03:44 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
swirling Flows in fluent 5.0 | pankaj Shukla | Main CFD Forum | 1 | November 16, 1999 12:27 |
