Combustion of wood
Old   November 10, 2004, 06:36
Default Combustion of wood
Simon Steinmeyer
I would like to simulate a combustion process of wood: I have definied the simplified mixture in prePDF and would like to inject the fuel as a non-premixed combustion. But I can't choose "prepdf-mixture" in the injection panel. How can I inject the fuel? In the "Boundary Conditions"-Panel, I can't find a suitable option, too.
Thanks, Simon Steinmeyer
Old   November 10, 2004, 18:53
Default Re: Combustion of wood
Ryan
To do a particle injection using the prepdf model, set the particle type to combisting-particle. The devolatilization kinteics and fixed carbon can then be changed in the combusting particle materials panel. To inject the fuel through a boundary condition (such as a velocity inlet), set the mixture fraction variable to 1. Use of a velocity inlet in this manner is generally used for gaseous fuels.
Ryan
Old   November 11, 2004, 05:26
Simon Steinmeyer
Thanks, that helped a lot.
Old   August 4, 2011, 09:26
aruv is on a distinguished road
Hello Simon.
I am working with Fluent to simulate the combustion of wood particles (edge ​​length: 8mm). I use the following models: Energy on, Viscous SST k-omega, DO Radiation and species non-premixed combustion. The wood particle is defined as a porous media and the porosity is changing with increasing temperature. This is done by an udf. The problem is that the particle does not heat up when I am working with the non-premixed model. My oxidizer comes with 1293 K as nitrogen and oxygen in the combustion chamber and the fuel (volatiles and co) is released as a function of temperature in the particle via udf. But the temperature in the particle doesn't increase.
Does the non-premixed-combustion model not include conduction?
Thanks in advance for your efforts.
Maria
aruv is offline   Reply With Quote
Wood Devolatilation and Volatile combustion nutow FLUENT 3 May 4, 2020 00:52
combustion of wood shavings Özer AYDIN FLUENT 0 September 16, 2008 06:40
Simple approach - solid wood combustion (newbie..) Dan Main CFD Forum 0 December 3, 2007 03:06
combustion of wood Özer AYDIN FLUENT 4 June 25, 2007 04:11
wood shaving combustion Özer AYDIN FLUENT 0 November 23, 2006 07:52
