How to get u,v,w velocities from Fluent Data file |
November 9, 2004, 10:58 |
Hi folks,
I have a fluent data file. I got this data file from 3D unsteady flow problem. In this data file i want to see the values of u,v,w velocities along x,y,z directions . I do not no how to get these u,v,w velocities. Please help me? Thanks in advance. |
November 9, 2004, 19:31 |
Re: How to get u,v,w velocities from Fluent Data f
export them to tecplot format ..
November 10, 2004, 10:36 |
Use the UDF Fluent macro in a function you can write using the C++ language or export the data you need on a FILE from the plotXY window. Luca
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
Import data from another .cas file of fluent | Umesh | FLUENT | 1 | August 17, 2003 04:51 |
