boundary condition
Old   November 9, 2004, 04:56
Default boundary condition
christian
hi folks do anyone of you know how i need to set the boundarycondition on a face that so it function as a valve (only inlet, no outlet). it must fullfill a tank with air, if the presure in the tank is less than the atmospheric presure. thanks christian
Old   November 14, 2004, 12:24
Default Re: boundary condition
H
after each time step, you can check using a UDF if the pressure in the tank is less than atm. pressure. If yes, then you can impose some velocity. Thus model the bc as vel. inlet. use define profile to set vel profile. depending on pressure values, the velocity is either zero (valve shut) or some positive value which will be decided from your valve characteristics.
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
