November 5, 2004, 08:47 |
sliding mesh problem
i want to simulate the unsteady flow of axial compressor. So i must use the tmerge to merge meshes of stator and rotor. I read the merged mesh in Fluent, and want to set the interface between the rotor outlet and stator inlet( rotor in the front of stator), but errors appear: boundaries too far apart.
Who know, what is the problem? The compressor rotates around X axis, in the position of interface, the X position value is completely same. So what is the problem? Thanks for your help! regards, annie |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
CFX Mesh Deformation problem | Silmaril | CFX | 7 | October 19, 2010 11:00 |
Sliding Mesh Problem | CC | FLUENT | 1 | February 9, 2009 00:26 |
Sliding mesh problem | Michel | FLUENT | 1 | January 15, 2009 11:18 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
