convergence problem
Old   November 4, 2004, 10:49
Default convergence problem
limseokmin
Hi every one. I'm facing with serious problem that problem dosen't converge. If somebody help me, greatly appreciated.
Problem description)
Large tank with small inlet & ourlet, contain wall which has heat flux to inner fluid. The fluid is liquid nitrogen. It's the cryostat.
My solving approach)
Use turbulent model(k-e model) - if do not use, the temperature near hear flux wall is much high. not phisical. Use varying properties(k, rho, C etc.) - polynomial interpolation (4th order). It's steady. It include enegy equation. Use default setting(relaxation factor, descretization scheme)
The difficulty is hard to obtain convergence. Especially the continuity convergence condition is main cause.
How do I can improve my problem solving conditions and reach the complete convergence. Please help me to follow up.
Old   November 4, 2004, 11:53
Default Re: convergence problem
Ertan
Why dont you try first laminar case (although it is not laminar), after the solution stabilized turn it into turbulent and continue to simulate. It may work...
Old   November 5, 2004, 00:43
Default Re: thanks for advice. but...
limseokmin
As you say, I try laminar case to solve that. but in the convergence grafical window, continuity value is maintained about 1 and it is not converge(infinite calculation).
What is the problem, you think.
I use tetrahedral automesh(mesh quarlity is not good, but it satisfies min,max required range). Is it effect calculation condition largely and shows poor result?
Old   November 14, 2004, 13:43
H
lower urfs will give you better convergence. does you model have any porous zone? also good quality mesh goes a long way in improving convergence. 80% of any CFD problem efforts should be devoted to creating a good mesh
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
