November 3, 2004, 22:57 |
porosity
hi,
i have a problem relating to the porosity. how do i define a porous medium in Fluent. the face permeability is not known, how do i calculate it. the problem is that, the flow occurs through capillaries. the diameter of the capillaries is known. how do i calculate the porosity of the medium to simulate the condition to have a capillary in the model.? requesting suggestions. |
November 4, 2004, 00:43 |
Re: porosity
you should do exeperiment and calculate as the help of fluent.
November 14, 2004, 13:48 |
Re: porosity
get a good book on hydraulic resistance - idelchik is good. find your case in the book fit your case to porous media model in fluent - read 6.19.6 User Inputs for Porous Media
November 27, 2004, 03:23 |
Re: porosity
Hi!
i also meet similar problem.you may define your calculation region as a porous medium.it is one of fluid regions. calculating the porosity of the medium need your hoop file using UDF . wanghong |
Problem in setting porosity region for rhoPorousSimpleFoam | run_cfd | OpenFOAM Pre-Processing | 1 | May 31, 2011 10:02 |
Porosity field in Fluent | wojciech | FLUENT | 1 | September 20, 2010 12:19 |
UDF for porosity | Giacomo | FLUENT | 3 | July 23, 2007 10:23 |
porous media with variable porosity | Kevin A. | FLUENT | 3 | December 24, 2006 11:56 |
Media with low porosity | Emmanuel Resch | Siemens | 0 | September 29, 2006 13:44 |
