How to set Water in fluent to compressible?
Old   October 28, 2004, 06:10
Default How to set Water in fluent to compressible?
Christian FH Biel
Hi there I need to set the material "water-liquid" to compressible for a evalution of the wavereflexionlaw in my Geometrie. If I simulate it with Air all works great. just need to get a wave into water. I tried it with a udf "pressure depended density" but I don't get a wave into the system.
thx
Old   October 28, 2004, 10:08
Default Re: How to set Water in fluent to compressible?
rossc
A ben voilą on cherche de l'aide?
Old   October 29, 2004, 02:33
Philipp Beierer
Fluent treats all liquids as incompressible. Hence, the only possibility is--as you already tried--to write your own udf. Special care must also be given to the numerics since you have a hyperbolic (equations) problem. Good Luck!
Philipp
Old   October 29, 2004, 09:06
Christian FH Biel
Thx Philipp Beierer As I changed the solver to "coupled implicit" my problem was solved. the udf was causing the divergence. Now it works.
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
How to define Saline water in Fluent Vin FLUENT 8 May 9, 2008 09:51
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
How to set environment variables kanishka OpenFOAM Installation 1 September 4, 2005 11:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
