error when mesh in Gambit
Old   October 27, 2004, 13:22
Default error when mesh in Gambit
icestar
When I meshed a cylinder(h=665m, r=1000) using Tet/Hybrid in Gambit, mesh space is 1m, it always had a error: Tetrahedral meshing has failed ofr volume 1. This is usually caused by problems in the face meshes. Check the skewnesses of your face meshes and make sure the face mesh sizes are not too large in areas of small gaps.
But I think the mesh size already very small. Does anyone know what I can do for that? When I tried 20m for space it works, but this mesh is not fine enough.
Thanks for advice.
Old   October 28, 2004, 03:58
Default Re: error when mesh in Gambit
Nick
Hey,
A thought on the matter:
Have you let GAMBIT create the FACE MESHES automatically? I've had some success before with manually creating quad meshes all around the volume, which I have then split into triangular ones.
Following this I've meshed the volume using either tet/hybrid- or TGrid elements.
Old   October 28, 2004, 15:11
par
Mesh the faces manually then use that scheme for volume mesh. (hope it solves the problem)
All the best
Par
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 02:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 14:42
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
