GLX extension Error
Old   October 26, 2004, 07:03
Default GLX extension Error
Andrew Garrard
Help! I just installed Fluent 6.1.22 on Red Hat 9. it all work fine until you try and open a graphics window, to, for example plot contorus or residuals. I get this error:
Error message from graphics function Show_Device_Info Server does not have a GLX extension.
Any help, please? I have run fluent on this machine befor without these problems.
Old   October 27, 2004, 07:27
Default Re: GLX extension Error
Rob Hart
Try running:
xdpyinfo
(or possibly xdpyinfo | more)
Does it mention GLX as an extension?
What about glxinfo?
Sounds like your x server is not configured correctly, so have a look at the log file for it (probably /var/log/XFree86.0.log) and the config file (/etc/X11/XF86config-4)
Rob
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
