Shock tube problem using Fluent 5/6
Old   October 24, 2004, 17:22
Default Shock tube problem using Fluent 5/6
Ravi
I have to give the pressure boundary conditions for a 2D shock tube problem using fluent. It may require use of the user defined functions I guess. Also the pressure BC should be given as a Pressure-Jump at a particular point. Can anybody tell me how should I give the boundary conditions.
-thanks, ravi.
Old   October 25, 2004, 01:23
Default Re: Shock tube problem using Fluent 5/6
jehanzeb
hay
solving 2-d shock tube problem in fluent u have to first specify two zones in gambit before u export the mesh and then u should patch the solution after initializing the solution.
u dont need the pressure jump condition.
bye
Old   October 27, 2004, 13:05
Nandu
Alternatively if you are only interested in either the driver or the driven section of the tube, then a simple pressure inlet with a single domain will also work.
Shock tube simulation in Fluent Vinoo_P FLUENT 28 September 6, 2018 01:21
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
Sod Shock Tube problem cfd Main CFD Forum 4 July 7, 2009 14:24
shock tube validation AB Main CFD Forum 3 December 10, 2004 08:31
shock tube: problem initiation Gareth Siemens 3 April 15, 2003 04:23
