Grid height - Rougness v/s Laminar Sub Layer
Old   October 23, 2004, 11:31
Default Grid height - Rougness v/s Laminar Sub Layer
Johnson.M
I am doing a roughness case study, hence I can only employ near-wall boundary condition implying my y+ <= 1. Hence my 1st grid cell height near the wall is 4micro m. I hence also obtain about 15 points in the laminar sub layer.
But maximum roughness height Ks is 2mm. According to Fluent User Guide, the distance from the wall to the centroid of the wall-adjacent cell should be greater than Ks, implying my first cell height should be 4mm!
If i increase y+ and make my first cell height 4mm, I neither get 10points within the laminar sublayer nor can i use near-wall modeling. I get about 2 points within the turbulent boundary layer!
What should I base my cell height on?
Thanks in advance, Johnson.Mendonca
Old   October 28, 2004, 15:18
Default Re: Grid height - Rougness v/s Laminar Sub Layer
par
I may base it on Re-turbulent number.
All the best
Old   October 29, 2004, 00:53
Lcw
If first cell height is less than roughness height Ks, how to mesh it ?
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
Error near boundary layer as 1st grid decrease CF Main CFD Forum 3 October 3, 2007 11:21
Using grid spacing calculator for laminar flow CH Main CFD Forum 0 November 5, 2006 01:02
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
