October 19, 2004, 09:55 |
face areas UDF
Hello all,
I am running a 2D simulation and I want to integrate a variable across a boundary. This entails getting the flux value, for example amps/m^2 and multiplying it by the face area in m^2. In the manual it gives the face areas macro returning a vector that is the normal to the face. I would like the actual value of the face area (or for 2D the distance between the two nodes of the face) in m^2, or whatever length unit it uses. Any help, as always, it truly appreciated. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
Area of a particular face of the cell using UDF | krish | Fluent UDF and Scheme Programming | 20 | September 16, 2015 05:08 |
Face handling in Parallel UDF | O.D.Y. | Fluent UDF and Scheme Programming | 0 | May 1, 2009 06:10 |
Face loop in a Parallel UDF | Dario | FLUENT | 4 | May 10, 2007 08:34 |
