Virtual vs. Real face
Old   October 15, 2004, 16:52
Default Virtual vs. Real face
Taskin
Hello all,
is there a difference between making a mesh from a virtual and real volume?
Old   October 15, 2004, 21:08
Default Re: Virtual vs. Real face
Lam
1)It's better to create a mesh using real volume. 2)Real entity has its own geometrical information. 3)Virtual entity refer the geometrical information of a real entity.
4)Last time, I created a domain that contains virtual entity in Gambit 2.0. 5)When I was doing some booleen operation, the output was not what I expected. 6)I solved this problem by creating a domain using real entities.
Old   October 16, 2004, 18:48
Taskin
so there is no much difference between making a solution using a mesh either created by a virtual or real geometry?
Because I built up a geometry and I can't make it real anyhow..
Old   October 19, 2004, 09:27
Jason
It's better if you can use real geometry, but this isn't always possible. Like Lam said, the virtual geometry references the underlying real geometry, which is what can cause issues. Geometry modifications (i.e. boolean operations and volume split operations) shouldn't be done on virtual geometry, and in most cases Gambit won't allow you to do it anyway. But virtual geometry was created to aid in meshing. You can still get a good mesh from virtual geometry, but you have to pay closer attention to it. Check your face meshes to make sure there are no highly skewed or inversed faces. Watch areas of complex curvature and make sure the mesh looks reasonable. As long as you pay attention to what Gambit is creating for face meshes you should be able to create a successful volume mesh.
Good luck, Jason
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
