GAMBIT crashes during meshing
Old   October 14, 2004, 08:35
Default GAMBIT crashes during meshing
Nick
Hey.
I'm having somewhat of a peculiar problem. I've created a couple of volumes from text files I've imported as ICEM data.
It seems that GAMBIT (2.1.6) can't quite manage meshing some of these volumes. Some of them are meshed beautifully on the other hand.
The problem manifests itself by gambit.exe having to shut down.
I haven't found this defect on fluentusers.com...
Old   October 14, 2004, 09:22
Default Re: GAMBIT crashes during meshing
frank
this occurs frequently. gambit is a dog!
Old   October 14, 2004, 13:47
SAM
haaahaaa
hehheeehhhhheheh
u r victon of gambit
Old   October 15, 2004, 22:04
Lam
Gambit and Fluent are still not user friendly enough and has plenty of bugs. I faces the same problem as well.
Old   October 19, 2004, 04:30
anni
Gambit sometimes crushes because there is not enough memory space in your computer. anni
Old   October 27, 2004, 05:31
zxaar
it is not always related to memory as i have also found out many times that for some imported geometry even if the mesh size is small it crashes, there are some internal bugs the way it handels the surfaces
Old   October 28, 2004, 04:02
Nick
Hi y'all!
I think you just hit the sore spot there, zxaar. I solved the problem of meshing a volume by first meshing the surrounding surfaces manually.
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 02:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 06:04
